R Racing
- 16
- 38
- St. Leonard, MD
Picked up my M920 a few days back. Did a light check and all was good. About halfway home the brake lights came on and wouldn't go off. There was no brake drag that I could tell and at a fuel stop felt the drums and nothing was hot. I checked the TM and no luck there and did a search on here. I was thinking possible brake switch? Does anyone have a PN for 1 and were to find 1 at ? and were it might be located on the truck ? Also the truck seems to take forever to build air pressure (10 to 15 + min ) and never seems to get above 90 PSI. There are no detectable leaks and when turned off it will hold the 90 PSI for more than 15 min with no hiss ? is there a air filter to the compressor that could be clogged ? Bad compressor ?
Thank you
Jim
Thank you
Jim
