M923 receiver/hitch assembly
TacticalDoc
26
Otisville MI
you can see what the hitch looks like here
http://www.amazon.com/gp/product/B0033WNJV4/ref=ox_sc_sfl_title_5?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I was also wondering if this would work if a hole was drilled out for the pintle
http://www.amazon.com/Curt-Manufact...p/B0007M1ZGE/ref=pd_sbs_auto_1#productDetails
if I remember correctly the distance between the frame is 29 to 33 inches...BUT I have to double check
so, here is another one that might fit also
http://www.amazon.com/TRAILER-HITCH...4723&sr=1-1-fkmr2&keywords=curt+hitch+29+inch
Or this one
http://www.amazon.com/TRAILER-HITCH...&sr=1-4&keywords=curt+hitch+29#productDetails
I might go with one of the bottom 2 because they are cheaper and rated at 500/5000
I think the 51017-29 drops down further by 2 inches
TacticalDoc
26
Otisville MI
After doing more research it seems like hitches for Fords from the late 1970s should fit the M939 (M923) series trucks...maybe! I haven't tried it but would be nice if someone can confirm this by measuring a F350 from the 70's. Does anyone know if this fits?
If they match up there are heavier class 5 hitches that I'd like to put on my truck
something like this fully welded class 5 hitch (2,400 TW/16,000 GTW)
http://www.etrailer.com/product.asp...1977&vehicleid=197713658#prod-acc-onlyreviews
Curt Hitch # C15300
Edit
44 inches wide....wont work
http://www.amazon.com/Curt-15300-Cl...F8&qid=1383649795&sr=8-1&keywords=Curt+C15300
zout
154
Columbus Georgia
I have all my metal to build a hitch on the back of the M909 after the Veterans Day Parade in Columbus - get started on it at least.
The bottom cross tube is 6 inch square 3/8ths steel - the remainder of the steel I have is 3/8ths.
I plan on towing nothing more than Debs jeep on a trailer with it so roughly the max weight I forsee is no more than 10,000 lbs.
When I get to it I will post up some pictures.
PaFarmer
35
PA
A lot of misinformation in this thread. I installed a receiver hitch for a 1980-1996 F series Ford on my deuce. The frame on my deuce, 818 and 931 are all 34" wide. The '99 and up ford F series are too wide. There are a lot of threads on this issue with the part number.
Hoefler
20
White Bear Lake,MN
Built this for my A3. I bought just the recvr tube from E Trailer. Had it welded to a 3" crossbar with some gusseting. Made bolt on side plates that lined up with existing holes in the farm of truck. The pictures show the first set of long side plates. I fount the placed the hitch to low-so made shorter ones and bought an aluminum adjustable drop hitch. I used all grade 8 hardware. The electrical device is a 24 volt to 12 volt trailer adapter-one end plugs into truck. The other end plugs to trailer pigtail. Works great-with exception of no electric brakes portion.
Pete
IMG_2723.jpgIMG_2775.jpgView attachment 529599IMG_2771.jpgIMG_2722.jpgIMG_2721.jpgIMG_2874.jpgIMG_2858.jpg
Smike740
15
Columbus, Ohio
I have been doing some research to add a hitch to a m923 and called Curt yesterday. Their hitch number 15400 or 15800 is made for a 34" frame which is what a m923 has. They are both class v the 15400 has a 2" receiver and the 15800 has a 2 1/2" receiver. When I install mine I plan to add 3" spacers between the hitch and frame to drop the height a little more.
TacticalDoc
26
Otisville MI
http://www.amazon.com/Curt-15800-Bl...f=lh_ni_t_mi?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
So why does it say
Product Dimensions 43 x 12 x 20 inches
Smike740
15
Columbus, Ohio
Here is a link for the 15400 instructions from the Curt website. as noted at the top of the instructions the hitch fits a 2001-present Chevrolet Silverado 3500 HD Cab and Chassis w/34" wide frames. I spoke with Curt yesterday and they verified this.
The dimensions on the Amazon website generally are for the box.
Also per Curt the drop from the top of the hitch mounting surface to the top of the receiver opening is 6 5/16".
I plan on ordering one today and mounting it over the winter.
https://www.curtmfg.com/masterlibrary/15400/installsheet/CM_15400_INS.PDF
dawico
Lampasas,TX
Please tell me more about the wiring adapter.
And can it be hooked up for brakes? Like if you had a brake controller in the cab? Or is that option out completely?
TIA
TacticalDoc
26
Otisville MI
Let us know how it goes. You will need a drop hitch or something else to lower it.
A drop hitch like this might be better than adding spacers at the frame http://www.amazon.com/gp/product/B008BXT1N0/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A3F85K2N3SOH2A
Or better yet something adjustable like this http://www.amazon.com/gp/product/B001GMTKW0/ref=ox_sc_sfl_title_9?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
MikeGuti
Albuquerque, NM
Yes it will. It is less that 12 inches from the top of the frame to the bottom on the pintle hitch. This hitch mounts on the bottom of the frame. I will probably build a hitch but any of these hitches would be fine.
