Completed. Total cost including transfer case, oil, steel,bolts, 2 U joints, two 4x4x12s, and reamer bits $350. About 10 man hours total into it of solid work.
Used 2 tractor drivershafts that go from the transfer case to the front tandem. Replaced the u joints with some moog. The other one I left alone. All joints are the 280X equivalent Would like to upgrade all of them to that style joint eventually. Just get rid of the companion flanges all together. Used the same transfer case bushings at the T1138 just ground them down to flat. The top of the transfer case clears by about 3 inches. Lower part of the case is higher than my larger fuel tank but i may invest in a rock guard. Runs well down the road. 50mph at 2000rpms in 15th (direct). Posted by RPMs/mph for 13-16th gears. For sure geared lower. I put it in R1 and it dug out of the sand it was sitting down in pretty much at idle on its own with a empty trailer hooked to it. I will monitor the transfer case temps on the next trip. Yeah I am going to lose some higher speed but the T1138 will not handle a bigger engine and it's power. Especially not with a transmission that is 95% efficient in front of it.
Transmission to Transfer driveline is raised by 3 inches. I had to cut the spare tire carrier to make the clearance. It just would not go up high enough. Not like I use it anyway. Output to front tandem shaft angles up almost 2inches and a 1.5" offset. This should be fine as the shaft has plenty of room for toward travel as well as upwards. I will figure the front driveline out after the big cam swap since I will be moving that cross member under the truck as well as using some HEMTT driveshafts instead of the 939s.
