quickfarms
- 25
- 48
- Orange Junction, CA
Check to make sure the selector shaft is moving through all of the gears
Do you recommend doing this by removing the pan or watching the cable move it down from the outside...?.....I have checked its operation from the outside and it seems to be functioning properly but without the pan removed I can't say the same for the lever actuating the valve body components on the inside.....Check to make sure the selector shaft is moving through all of the gears
The device under the shift cable with a line in and another out is the fluid valve for the converter lock-up (didn't see it the first time I looked at the pictures) the little switch by the lever is the neutral safety. I suppose it's possibe the shaft broke inside with enough material left on it to move into reverse. (even a broken crankshaft in an engine will continue to run). the lever & nut look undisturbed, so it's not likely the problem, but always check the easy stuff first. (IF for some reason you pull that shaft, it comes out from the inside, be sure to de-burr the outside before trying to pull it through.Parking brake is completely disengaged when I am attempting to put into gear, made sure of that numerous times in initial investigation. I wi go ahead and remove nut n flat stock tonite and see what I find. I am pretty certain there is nothing like the device you described on the passenger side of the transmission but I will look again......only device I was thinking of that you described was that governor valve on the driver side in the top of the first picture I posted.
I have a 1986 m923 runs great all works. Trans will not shift to 4&5th gear. No slip, nothing burnt, down shifts and high and low work the same. Is there a governor on the trans? This is a Air Force five ton. Please help I’ve tried everything
