Cobra03
- 0
- 6
- Imperial, MO
I got my 923 in December, and when I drive it, it is so loud. I thought it was nature of the beast. I would have to wear earplugs. This thing shook, shimmied, banged down the road. I checked all ujoints, ok. I noticed that the output flange on the front driveshaft was leaking really bad. I removed the front driveshaft and noticed that the output flange has a ton of play causing the seal to leak. At the time I couldn't get the nut off the flange with my 1/2 inch impact. I haven't had time to put my 3/4 on it yet. Is there a way to tighten or shim this? Do I replace a bearing? Replace transfer case? I will attach a video on here. I drove the truck home from work(40miles) and it drove like a dream with the front driveshaft out. It had minimal tire noise, but that was it! It drives like I always thought it should sound. I would rather not put a transfer case in it. What do you guys think?
https://vimeo.com/161219441
