M923A2 White smoke issue
Katavic918
54
Maryland
I am in the process of buying an M923A2 with an 8.3 in it. Everything looks good except when it starts there is a ton of white smoke (fuel not coolant). This will continue for about 5 minutes and then will start to slowly reduce. Once the motor is warmed up it still has a haze to it but the weird thing is it will almost go away between 900 and 1600 rpm. Anything above or below that and it will start to smoke again. BTW, this is without driving the truck and warming it up at a fast idle. I have replaced the fuel filter but that's as far as I have gotten. I'm hoping it's injectors and nothing more serious. Does this sound familiar to anyone. Oh, also want to mention that it has IP150 written on the door in marker. Thanks for any help.
snowtrac nome
139
western alaska
Usually its just injectors, but it also could be retarded timing, especially if the pump looks like it had been changed. One other thing could be air in the system, but on the c series if it has any leakage in the supply system you will usually not start with out bleeding the system.
Katavic918
54
Maryland
Thanks for the quick reply. All I know is the motor was replaced or rebuild by the military in 2009. (pretty much a crapshoot I know). The pump looks like it has never been removed.
snowtrac nome
139
western alaska
If it was rebuilt at a depot facility, it should have been ran on a dyno to prove hp and check for mistakes, if it was bought through a contractor who knows. most likely it just needs a set of nozzles or a check and adjustment of timing.
Katavic918
54
Maryland
Haven't checked the history but from what I can tell it had a turret mounted which could suggest deployment. Also it had a bottle of window cleaner from a manufacturer in Kuwait.
Lukes_deuce
124
Long Island, NY
As you stated, if the smoke is unburnt fuel, try isolating each injector when running to see if there is one culprit. Could be one lazy injector when cold. Im pretty sure I have a lazy injector but its a dark gray color. It does go away once warmed up. If any engine sits for a long time, all sorts of weird things can happen.
