- 12,195
- 320
- 0
- gainesville, ga.
A steep sand hill WILL be hard to go UP, no matter what truck you are driving, even a dozer will have trouble if steep enough.
It's in the TM and on the dash....The tires on that truck should have runflats. You can air way down without the tire coming off the rim. Weight is critical for traction but you have to reach a happy medium. Did you say you tried to back up in Low Range? That is a good way to destroy a transfer case. Never back up in Low Range in a 900 series. If it isn't in the TM it should be.
