M925A1 Beeping?
SSchwake
Kirkwood, Missouri
Finally got my new toy home (all is good) but it's letting out a quiet beep about every minute or so when it's completely powered down. My old 923a1 was doing the same and I found the PCB bypassed - once I replaced it, the sound went away.
Unless it's bypassed in a way that's not obvious, this unit's PCB seems ok.
I don't want to ignore it in case its a battery drain.
-Anybody ran into this before?
Ajax MD
1,414
Mayo, MD
The main battery switch is off when it does this?
I've never heard of this before. Did a previous owner add some aftermarket gizmo that is tucked away somewhere?
SSchwake
Kirkwood, Missouri
The beeps sound as if a short pulse is being sent to the parking brake buzzer. I recently replaced all my batteries and cabling, so my initial thought was incorrect connections. I’ve double checked everything - it’s not that.
SSchwake
Kirkwood, Missouri
I've had my PCB disconnected for a few days (which stopped the beeping). I reconnected it today, and the beeping did not return. I'm assuming I have a weak contactor in the PCB (guessing).
Thanks
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Or a switch that isn't cutting the power off completely Could be either one with an intermittent issue
