red
- 22
- 38
- Eagle Mountain/Utah
RT=Roadranger twin countershaftOkay love the information but need a guide to understand what I am seeing, what does RPMTLOF stand for? Each letter please.
Sent from my SM-G930V using Tapatalk
RTF=twin countershaft with forward mounted shifter
RTO=twin countershaft with overdrive
RTOF=twin countershaft with overdrive and forward mounted shifter
RTLO=twin countershaft with low and overdrive
RTLOF=twin countershaft with low, overdrive, and forward mounted shifter
RTOO=twin countershaft with 2 or more overdrive gears
RTOOF=twin countershaft with 2 or more overdrive gears and forward mounted shifter
There are other letters but this covers the majority of the eaton fuller road ranger twin countershaft transmissions.
A forward mounted shifter (F at the end of the letters) places the transmission shifter roughly where the spicer 6453 shifter is in the m809 series trucks.
After the model letters come the model numbers. There are normally 4 or 5 numbers. 4 numbers are transmissions rated for less than 1,000ft/lbs torque, 5 numbers are rated for over 1,000ft/lbs torque.
The first number (when 4) or first 2 numbers (when 5) stands for the rated maximum torque.
The next number designates which design level it is.
The last 2 numbers list the number of forward gears.
Take RTOO 14613 for example. Twin countershaft with at least 2 overdrives.
Maximum torque rating of 1,400ft/lbs
6 in the design level (multi mesh gearing is what 6 stands for)
13 forward gears.
Now take RTOF 9513. Twin countershaft with overdrive and forward shifter.
Maximum torque rating of 900ft/lbs
5 in the design level (coarse gearing)
13 forward speeds.
