Bowtie70SS
- 2
- 16
- Goshen, Ohio
My neighbor has a M931 (I think) and it is not running right. We did a local homecoming parade last week and his truck started to run bad on the way home. He was idling in traffic and said he heard the engine sound change. He went to take off and the truck chugged and black smoked. He made it home and called me to check it out. I have a deuce and also have a pretty extensive mechanical backround on gasoline stuff. I checked the easy stuff and ended up changing filters and draining some fuel. It seems to run a little better but it is obviously only running on 4 or 5 cylinders. It is smoking at idle like raw fuel smoke. It has a noise in the engine but it seems to be from the middle or top. I was told that insufficent pump pressure, a bad injector, or a bad head gasket could be the cause. I came up with the idea of a bad rocker arm or push rod but have not pulled the valve cover yet. Where do I start? I dont have any diesel tools but am very mechanically capable. I would like to do some preliminary tests before just telling him to take it somewhere.
