The transmission on my M931 shifts and pulls fine but the only problem is that when you put the selector in any other position besides 1-5 it just goes ahead and shifts like it was in the 1-5 position.
If, for example, I put the selector in 1-3 it should limit the trans to shifting no higher than 3rd gear....but it just goes ahead and shifts on up through 4th & 5th.
Been looking through the manuals and the P2P program but haven't run across any description of how the control works.
Has anyone experience this or can you tell me the likely cause? Wouldn't be a problem to run it like this unless you need to limit speed downhill by manually forcing it to stay in a lower gear.
Thanks
Thanks
