- 6,858
- 685
- 113
- Stratford/Connecticut
My new 931a2 was delivered today. I have a 923a2 so I know pretty much what I am doing but am definitely no expert. The air pressure builds to around 115psi and it builds a little slower than my 923. I like to run at 120-125 the ctis seems to like this range it won't start filling till around 110psi. I uncapped the air regulator I couldn't remember which way was more and which was less so I loosened the nut and started backing it out no change though. I ran it in also no change. It did seem like there was a little oil at the bottom edge of the ring that holds the adjustment screw setup in place. I shut it off and checked all over for leaks no hissing and it sat for a good half hour and still held 80psi. The brake release is all the way out nothing leaking and the trailer brake control is out all the way. It only has 6 hours and 130 miles on it could the compressor be on its way out or am I overlooking something?
Will
Will
