What are some safe options to replace a broken shear pin on the rear main winch? Would a grade ? bolt work as a replacement or ? This was the 1st time Ive ever put a load on it and the drum stopped moving completely. I got under there and saw the hyd motor would turn but the coupler was spinning on the winch input shaft. What I could see is a silver pin with a cotter pin thru it.
