SLOrazorsedge
- 5
- 18
- San Luis Obispo, Ca
Happy Sunday all! I have a M936A1 wrecker with NHC250 motor. Long story short, one fuel tank was contaminated, pretty much overcame the frame mount filter and the PT pump and engine ingested the contamination. The motor had a severe "diesel knock" and ran very rough. I've cleaned the tanks, replaced the frame mount filter, blown the fuel lines out back towards the tanks, have clean fuel, Diesel Power injector cleaner and premium 2-stroke added. The truck still starts with the bump of the starter and largely sounds very good again. I can run the RPMs up from idle to 2100. There is a bog down from about 900-1300 RPM. Took it for a drive and it is anemic on power. Once it shifts to 3rd, forget it. TM's talk about cleaning the PT pump screen. No problem finding said screen on my M923A1 pump, its located on top under a hex bolt. The M936/M936A1 trucks use a different PT pump, They have a VS governor for the auto throttle during crane use, PN#3045424-9254, NSN#2910-01-218-5158. Both myself and another SS member have searched hi and low and are unable to locate the PT pump screen on our wreckers. Either the PT pump is delivering inadequate fuel delivery to the injectors i.e. plugged screen or what? Anyone here advise on where the PT pump screen is found on the wrecker pumps? Any advice on the loss of power? Thanks for any input.
