bmdupont
- 0
- 1
- Portland/OREGON
It is always a good idea to disconnect the ground cable before doing anything electrical, especially cannon plugs, control box, etcIt's a ribbed black box mounted up in behind the ignition switch area. It's marked 'flasher directional signal' so there's no mystery about if you've found the right one. Before you swap out the box make sure you check the cannon plug for corrosion as well as all of the grounds you can find. View attachment 574651
