jmenende
- 378
- 63
- Puerto Rico
Yes, its grounded. What should the ign terminal read? ThanksI might add you need to park the truck until that is resolved, bulbs and start box will blow.
It should read the same voltage as the batteries or real close anyway, if you are seeing 34V on the IGN terminal then the reg is likely bad.Yes, its grounded. What should the ign terminal read? Thanks
Is the regulator repairable?It should read the same voltage as the batteries or real close anyway, if you are seeing 34V on the IGN terminal then the reg is likely bad.
No. It is “potted” meaning covered in epoxy and such.Is the regulator repairable?
