Manifold Heater Leak
Dukeman
Albuquerque, NM
After all these years, tonight the manifold heater starts leaking. There is a small hole just under the fuel inlet. Fuel just streaming out of there. I have never used the manifold heater, should I just bypass it? Do you just plug the inlet tube. Looks like just a 1/4 npt plug? Give me some advice. (Needle nose pliers pointing to the hole.)
thanks!
fpchief
220
South Alabama
And if you remove the different parts, it cleans up the engine some. I took my Intake to napa and had them match drain bugs to fit the holes left behind. I may or may not have used a little JB Weld also....
