oregonfirefighter
- 1
- 0
- Medford,Oregon
Output of the GI transformer is 1200 watts. Most of that is used when the MBU's start up. The military generator for use with these units was a 2kw machine. If they have 50 percent efficiency then 1200 watts out means 2400 watts in, 2400 divided by 120 volts equals 20 amps, but that is with six burners going, you only want to burn two burners, a third of 20 is a little less than seven, so your answer is seven amps. I could have just given you the answer without the explanation and your question would have been satisfied. Explaining HOW the answer was derived should give you the insight to be able to answer similar questions in the future, for yourself or others.
