MBU v3
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I'm not able to use a pc till I get back home, then I'll download the TM.
Anyone know what error 11 and error 13 is? Trying to fire this up on the bench.
jasonjc
290
Gravette Ar.
Its easy to look in from the side to see in the igniter is working or not. Its a "U" shape wire that glows white hot. You can also hold down the start button to over ride, to try to get the air out.
SCSG-G4
PSVB 3003
5,370
3,383
Lexington, South Carolina
TM says to hold the "START" button in for 30 seconds at a time if it is having problems getting started (up to four times, then pull and go through the troubleshooting procedure. Had one early this morning got an ER05, disconnected it and pulled it out - sure enough, it had a flame going. Blew it out, reinstalled burner, and it fired up just fine.
gimpyrobb
27,786
755
Cincy Ohio
This is an MBU only sitting on the bench. Even if I hold the start button, it goes "Psst" and right to error 13. At first I didn't have the fuel full to the brim, now I do. No more error 11.
Is it supposed to keep doing something if you hold the start button, mine does not.
