RWG421
- 0
- 6
- Chandler , AZ
I just picked up my first Mep 002A, and for the life of me I can’t quite get my head around the Ammeter-Voltmeter Transfer switch (AVTS) Function.
My Question is; with the Reconnection switch set to 120/240 1 PH, page 2-4 & 2-5 of the TM suggest that I set the AVTS to the "4 o’clock" setting ( Amps L3, Volts L3-L0 Phase 1) per table 2-2 on page 2-4 of TM5-6115-584-12
So if I measure across L3-L0 as the tables suggest I will read 120 volt, and I will wire L3 & L1 as my hot legs and L0 as neutral.
I know the AVTS setting contradicts a post on "MEP-003A hook up question” 9/12/2009
So this is where my confusion lies
Are Either Single Phase option on the AVTS (2 and 4 o'clock position) available to me as long as the Reconnection switch set to 120/240? If so how does this affect my connections at the load terminals?
Additionally does L1 become the neutral under 120v 1 phase 2 wire setting ”Figure 2-4 page 2-5” of the TM.
If so is this accomplished by the AVTS or the Reconnection switch position?
Thanks in advance for any insight into curing my brain damage.
