BrutusM37
- 4
- 8
- Attleboro, MA
Where does the return line from the injection pump to the fuel tank connect on/near the injection pump?
Bought a Mep-002a a year ago, runs fine, carries a load, etc. Fuel return line (says “From Inj Pump” on tank end) was just dangling under the engine. Checked the TM but nothing definitive in the schematics. Is there supposed to be a tee fitting on top of the IP where the return lines from the injectors join and connect? Pictures attached.
If that’s the case, I’ll gladly buy one if someone has a parts unit available unless it’s a generic item. The next question is why did someone modify it?
