Spring1898
- 0
- 0
- Erie PA
Hello All,
Was working on another MEP-002a and just got it ready to test start and was going to prime the system.
Hooked up the batteries with the master switch in the off position, and when the battery was connected the fuel pump started running?
I double checked the position as off and out of curiosity switched it through the other modes. Preheat doesn't make any noise, but the starter position worked normally. "prime" positions don't engage the fuel pump.
I unplugged the battery and noticed the glow plug area was hot to the point you wouldn't want to leave your hand there long.
It is almost as if all the positions shifted?
I am going to leave it alone for a while and will take a peak behind the panel later on.
Any ideas what it might be?
Mechanical things I am okay with but I know next to nothing about electrical.
