Milhouse
- 0
- 0
- Tilton, NH
I have an MEP-002A that I just replaced the regulator on because I have a 320V output, and its still the same, checked all wires (I'm a tech and work on these all the time), checked to make sure i had no loose connections on the bus bars, control box plugs etc... everything seems ok, voltage dial has no effect at all, solid 320V output (and yes, phase switch is ok, cycled it to make sure I had good contact too) is there somthing else that might cause this to not regulate?
