- 2,789
- 6,667
- 113
- West greenwich/RI
Peter, thank you for the info, I'll take a look those IC's today. Meanwhile, I tried the other circuit on the generator Friday night but found (as I suspected ) that a 4 Hz change at the generator only registered as about 1 Hz change on the meter (the circuit showed a 100uA meter instead of our 200uA) BUT, I had built the circuit with the same 100K 2w resistor that the schematic called for. On my first test board I used 4 100K 1/2w in parallel, which I thought would yield 100K 2w but in fact it is giving me 25K so I'm going to throw that resistor pack back in and see how the gage responds to changes in frequency. Maybe get some of the tach IC's on order as well.
