fastbackperry
- 0
- 0
- auburn washington
Thank you in advance for diagnosing my Hertz question.
I recently picked up a 003A which runs great and generates power great. The voltage gauge is at 240 but the hertz gauge doesn't work consistently. Only once have I been able to adjust engine rpm to achieve 60 hertz. I know that idling these is not good as I have another one hooked up to the house that works great. I noticed when I shut the generator down and the engine rpm's were coming down that the hertz gauge rose as the rpms came down then dropped as the engine came to a stop. My other 003 has not been consistent but usually works fine especially when I power the house. I've cleaned the ground lug on the unit as William at Delks suggested but no change. He told me that I should have 5 volts direct current at the gauge if I am remembering correctly. I'm seeing 3-4. Any help of what I should test or look at would be appreciated. Once I get this fixed I plan to sell it but don't want to sell it if something is wrong. Thank you again in advance.
Perry
Perry
