nofear
- 0
- 1
- Indianapolis/IN
Hi all. I have a MEP-005 that is not producing power out via the Lugs on the side nor the convenience receptacle. On startup, Freq stays at 49Hz and voltage at 0. I startup at full throttle (not sure if it is 1800 rpm). I hold the on switch to ON for about 3-5 seconds for all the (most) of gauges to come up.
L1 will have jumpy hz, meaning it might jump from 28 up to 40 down to 18 then steady out about 23. No voltage from it to L0
I have the TM so I feel I can dive into things, I'm just not sure where to start looking at. Any thoughts/advice?
