Woodmaneng
- 0
- 1
- Cave Junction, Oregon
Hello All,
I am new to generators, and the learning curve is steep when you are desperately needing a functional unit.
I purchased a MEP-005 from a dear cousin. Former forest service unit. It runs well. It was outputting 120v and 240v right after I brought it to the shop. I was able to read 240 volt leg to leg when initially checked. I was using the generator during a power outage for 120v. Suddenly quit producing after about 20 minutes of use. Now when checking voltage I only read 460 volts from any leg to neutral. Only .8 volts leg to leg. yes point eight volts.
A Newage Stamford SX460 is installed, and all of the original electrical component's have been removed. I cannot use the original wiring diagram for trouble shooting. Can the sx460 work with a 3 phase system? I have poured over the spec sheets of various AVR suppliers / MFG's. I will be doing all the work myself.
My thought is to buy a new AVR and start from scratch. Can anyone point me in the right direction.
I bought it to supply my machine shop with reliable 60 amp 3phase service to only use on my 3 phase equipment. I only use 3 phase occasionally so a generator is a good option vs getting a power company to install 3 phase service. I am very rural...
Thanks in advance, I know this is going to be a mind bender.
