generatorshawn
- 7
- 8
- gainesville fl
hello guys!
so finally got a new engine for this unit and after rebuilding the injection pump on a CRATE motor lol finally got it to start and run the unit itself has sat for roughly 4 or 5 years after the previous owner threw a rod out the side of the block. on start up and ran the unit up to around 1800 rpms runs great but no voltage or hurts readings on the gauges was able to close the breaker and same also tried with the volt meter and it confirms nothing. tried to filed flash the generator by holding the start switch while running voltage climbs to about ~120 volts and the hertz go up in about 2 or 3 seconds but as soon as i let off the start switch the voltage drops away in about the same time. at this point im stuck on what to check next i assume its a issue with the voltage regulator but don't know what to check or what likely culprits turn up on these units.
cheers! shawn
cheers! shawn
