MEP-016B with SX460 Voltage Regulator
derf
13
LA
Today I verified an MEP-016B will work with an SX460 VR. I wired the gen output output single phase 120 and set the jumper on the SX460 for 120V use. They do make three phase VRs but I did not use one. I am not sure if the SX460 will work in three phase applications but there are other, similar units made for three phase heads. The SX460 I got is actually a Chinese clone, available on ebay for around $60. As far as I can tell it is an exact copy of the original Stamford, and sold by many vendors for much more $$. The SX460 features voltage control, stability control, and frequency roll off that cuts the power if the frequency gets out of range.
Specs:
http://www.northern-lights.com/PDFs/manual_pdfs/SX460.pdf
This reg taps 120/240 output to make the DC field output, so it should work on many different gens, both 1800RPM and 3600RPM, and can put out like 90V DC for larger generator fields.
wciguy
Lubbock, Texas
Same experience here. Mine did not work when I first hooled it up. Reversed the field wires and it works perfect. Seems to be polarity sensitive. Much more stable than the original regulator.
Beerslayer
55
Tualatin, Oregon
Derf, would you please post up photos of how you hooked it up? Wire numbers or points where you made the connections would be a huge help.
Also, how/where did you make the taps for 120/240 with neutral?
Thanks!
derf
13
LA
Here is a short video:
[media]http://www.youtube.com/watch?v=iDDutMmuYcE[/media]
I'm planning to mate the Yanmar to a larger gen head so I did not wire up the outputs. I just wanted to test the VR.
