miltrux
- 0
- 0
- South Florida
OK, got my hands on this back in '05. Back in '09 the regulator fried and I replaced it with an electronic unit (see older posts). Have never had the need to use it but start and run it every month, under load.
Recently, it's been either cutting out altogether, by first slowing down like it's running out of fuel, but that can't be it cuz I have it running on LP, or it just quits. No attempt will get it to fire again. I check the LP flow and it is flowing, try to fire with ether but no luck. It will fire again only after I let it sit for awhile.
Sounds like it's overheating. I have all covers in place and the location provides plenty of airflow around it.
Is there some sensor in line someplace that would be causing it to shut down if it gets too hot? If so, are they prone to failing like the regulators do? Or, is there something that I need to look into otherwise, like something else altogether?
It's prime-time hurricane season here and I have invited a lot of folks to spend time here in the safe house in case we get hit, but 20-30 mins of electrified comfort out of every hour is unacceptable.
Any thoughts/advice is most welcome.
Thanx much.
Ken
Thanx much.
Ken
