- 16,494
- 23,483
- 113
- Burgkunstadt, Germany
We're good Tom. How are things in your neck of the woods? I picked it up from a guy I did some work for. Actually bought a gin pole truck off of him and he said "I think I've got something else you may be interested in."
Now for my next question: Is the S2 toggle switch a "divided" switch? That is, is the right side of the switch not connected to the left side. I thought I had a bad switch and replaced it with an off the shelf on-off-on toggle switch and now it won't start. I have checked resistance between the negative battery cable and the contacts of switch S1. Less than an ohm of resistance between battery cable and common of S1. Meter shows open between battery cable and start terminal of S1 when in start position. Meter also shows less than an ohm of resistance between common and start terminal of S1 when in start position.
Just what switch are you talking about? S2 is the ammeter phase selector. That should have nothing to do with the start function.
