I didn't know you did a short video of flashing the genset! Just came up after the new video. Now I need that diode and I'm going to check that voltage adjuster...might get power out of it!I wanted to revive this old thread in case anyone is still watching.
I kept some of the parts when I parted this out. One of the was the potentiometer for the voltage adjustment. I grabbed it from my parts bin to use on something & went to use it with no luck. Tested it, and it was dead! Basically no reading (open) across almost the whole range.
So, I am thinking.... could the issue with this generator have been this the whole time? If the POT was bad, it would have made the voltage adjustment call way off, and made the regulator put out bad AC voltage as well.
I just HAD to come back when all this came racing back into my head. Kinda disappointed if this is the case, but, someone else can hopefully learn from my mistake hopefully.
I just got 2 more of these generators & they are in great shape with really low hours. They don't need anything except fuel lines, filter, & fuel! So, I'll be learning about them again.
Sent from my SM-S906U using Tapatalk
