WillsC
- 0
- 6
- Inverness, FL
Just ordered and looking forward to installing it.
Very soon!Can this be used on an 804a??? Please say yes!!
Question, I am interested in this product strictly for monitoring the health of the gen set from inside the house. Is it live data or does it update every couple mins? Also does this alter the way the gen set works manually at all?Since my venture into developing the replacement MEP831A Governor Controllers was a success I thought I'd revisit MEP remote start/stop with parameter monitoring.
About 2 years ago I developed a similar capability. However the control components were a closed design, didn't use WIFI and was not readily producible.
So.. Here is the 2018 version of a similar capability except all control is via WIFI. In this demo I'm using an old cell phone with just a browser. No "app".
Prototype starting a MEP-802A via WIFI. Controls all phases of startup such as PreHeat, Priming, Starting, Running, Closing the Contactor.
Sequencing and parameter reporting are accomplished with a small WIFI microcontroller that hosts the web pages and acts as a WIFI access point.
Live data streaming of generator and engine operating parameters.
- AC Voltage
- AC Frequency
- % Load
- Coolant Temp
- Fuel Level
- Oil Pressure
- Battery Voltage
- Air Temperature (Not functional yet. Awaiting sensor delivery)
Includes remote shutdown functionality also. Opening the contactor, Cooling down and Shutdown of the genset.
Genset can also be started and stopped manually.
Wiring from the controller connects to the meters and switch's in the control cube. Only 1 generator wire needs to be cut and spliced into. All other connections "piggyback" onto existing terminals of the meters and switch's.
WIFI connection is direct from the cell phone to generator. No router used. Password protected connection for security. 200'+ range.
Generator can be controlled by any device with WIFI and a web browser such as a Laptop, Cell Phone, Tablet, etc. No "app" needed.
Will be continuing to test and improve over the coming weeks and possibly months.
If there is enough interest I may persue producing the controllers once the design is solid and proven.
For now I'm be targeting MEP-802A, MEP-803A & MEP-831A since I have an 802 and 831's to integrate with.
The MEP-831A will have less parameter monitoring due to it's lack of engine Temp & Oil pressure sensors.
Thoughts?
It works great, I have oneCan it be integrated into a network of must it run WIFI stand alone? Can it be run from a PC or only from a smartphone app?
If you absolutely have to access it via another network you can setup a RaspberryPi using the graphical version of RPi OS. You'd use the RPi's WIFI to connect to the generator controller and its LAN connector to connect to your main network. You would use a remote desktop app to view the desktop on the RPi from other devices. Not elegant but functional.Can it be integrated into a network of must it run WIFI stand alone? Can it be run from a PC or only from a smartphone app?
I was not expecting it to reach that far. I'll have to get one soon.On an 803 I've tested it to ~600' line of sight.
