On the few machines i have been refurbishing, I just have been cutting the factory hoses crimped ends off (takes a little work to not tear them up) and using the barbed ends with Gates 4219XL, 1/4" fuel line from Orielly's Auto Parts. I also use the fuel injection clamps instead of the worm drive ones, they hold better in my experience.
I also have been reusing the stainless hard line, as well as some new i bought to reroute the lines for my liking. I also have been removing the factory fuel filters and doing different filter setups. This current machine I've got a single filter base with Baldwin BF1212 water separating filter.
I relocate the oil pressure/dead crank switch plate up a few inches and mount the filter under it.
I cut the round banjo fitting off the factory hard line that feeds the injection pumps and just run the filter output onto the hard line. Also replace the 5" to 6" fuel lines from the hard line to the IP's as well as all the 1/8" return lines.
Here are a few pictures of what i have done.
View attachment 809700View attachment 809702View attachment 809703View attachment 809704
