asilitch
- 5
- 3
- Richmond VA
Thank you all very much for the wealth of information and experience compiled on this site regarding these generators:
I have recently acquired a low-hour early-production 803a.
I am trying to understand the design-flaw that leads to the rectifier bridge shorting out in the voltage regulator (and thus to the destruction of the QUAD winding -- unless a fuse is added to the circuit).
At this point it seems to me that the fundamental problem is that the field flash circuit can provide excessive voltage to the field windings, and cause the QUAD winding to put out voltages much higher than the design voltage. Is this more or less correct?
The TB suggests that the voltage regulator should be re-designed with diodes in the quad circuit bridge that can withstand a higher PRV. The suggestion in these posts is to add an MOV across the QUAD windings to limit the voltage seen by the rectifier bridge. However, if the root problem is excessive voltage from the field flash function, why not add a clamping circuit between the field flash resistor (R14) and diode (CR2)?
If I am making a gross mistake here, or if this might be an effective solution, I would be grateful to feedback from those with more understanding and experience.
Thanks!
Alec
Thanks!
Alec
