- 3,753
- 5,685
- 113
- MA
A machine that I have had here for a number of years, that has finally come up to be moved out. Its not a turn key ready machine, but is an excellent unit for someone in the northeast who is willing to put some elbow grease in. The good and the bad below:
Good
Runs and makes power (not load bank tested)
All gauges read true
Upgraded to E1074 fuel pump (had a dead square Facet)
New return fuel line
New double aux fuel float
Quad Fuse Upgrade with MOV installed
Rodent mesh applied on air intakes and below engine bay
Power Entry port added to the side so you can run a battery tender on the internal batteries when not in use
Includes Aux Fuel line
Needs work
It has crankcase pressure. It sat here a number of years without being run, and I have no idea how many years it sat before I got it without running. Nature of the beast. I believe the rings may be stuck, as it only has 385 original hours.
The price is my landed cost (auction cost, premiums, taxes, and freight), and does not have any of the replacement parts $ or time put into it. I just want it to find a home for someone who wants a good machine that needs some work.
Local pickup or can ship anywhere in the US by tractor trailer. Thanks
Good
Needs work
