Wix 33348 also same as NAPA 3348 and Fram C11941 and comes with gasket. Also mounts in canister as shown in three pics below. I couldn't find any pics or illustrations in tech manuals. Hope this helps....I appreciate others posts, as being very helpful in getting my 802s and 701 running great
View attachment 488168View attachment 488169View attachment 488167
sounds like the gasket is still not seated right, or the base is dirty. clean the track well in the base, make sure the filter housing is also clean and free from nicks or burrs, if it is not flat it will also do this, you can check by placing it face down on a perfectly flat surface. I use petrolium jelly on the gasket, this allows you to stick it up into the track it needs to be in, then install the canister, before tightening the canister just bring it up snug, then rotate and wiggle it a little, you will feel it seat into the track, sometimes these canisters are warped slightly and you can get a false "tighten" and just have to make sure it is fully seated on the gasket before tightening all the way.
Wix 33348 canister cartridge comes with the top large diameter o-ring.Anyone have a o-ring number for the fuel canister? (Secondary) wix/ Baldwin
can anyone confirm it's wix 15405?
