novaman
- 0
- 0
- michigan/Livonia
Im doing load tests on my new gen. Runs great even starts my 3 ton ac. I can load it up with heat guns and heating elements up to 7500 watts continuously but every 45 mins or so I see a puff of smoke come out of the rad air ouet on top. I open the side door and it looks like from the throttle cables down is doust in fuel but no where is still leaking even while still running. I hose it all off let it dry all still while under load. It drys then 45 mins later same thing. Can't find where its coming from. Fuel filters are dry as a bone. hoses are tight. Except the fuel drain hose going into the tank it swivels. Not sure if that's normal but if that's what's leaking why doesn't it leak all the time
