ethernaut85
- 1
- 3
- WV
Hello Everyone
I recently picked up a 802a that does not charge. I have checked output at the alternator by placing a multimeter across the positive and negative leads as described by the TM. I am getting around 24 volts +/- 0.5v. According to the manual, it says that the alternator needs replaced if the multimeter reads less than 27v or so. Does anyone have any suggestions on anywhere else to look to make sure that its not the alternator but something else? I used my multimeter on the diagnostics port on the front while the genset was running and all the readings were in the 22v range except (d) which is the battery charging circuit which was ~24v.
In addition, I've read about the remote fuel drain fitting leaking which my generator does. How can this be rectified? We started taking off panels to get the fuel tank out but 50 bolts later we are still shy of removing the tank.
Thanks in advance for the help!
