All
The generator is working! Thanks for the help everyone.
What I think happened:
I believe the fuel in the injector pumps dried out after 20+ years sitting. A residual film was left on the pump's cylinder and piston walls. When I cranked the engine the cam internal to the motor pushed the pump's piston up through the residual film. But, the pump’s returned spring was not strong enough to push it back through the film. So the pump stayed in the up position and stopped pumping fuel to the injectors.
What I did to fix it:
Disassembly:
1) Remove the two pumps and the 4 to 5 spacer gaskets each pump had. I marked one pump "L" (Left) and the other "R" (right). I kept the original gasket set with each pump.
Note - The gaskets are made of tuff plastic and are reusable. Their combined thickness sets the cylinder’s timing. So, don’t mix and match. If you need to replace one or more spacer gaskets, then, measure all them together and buy the right amount to bring the total set to what you measured.
2) Remove the value body assembly cap from the pump by using an 18-mm socket. Then remove the value assembly.
Note - There are several parts to watch for. These are: a spring, the upper spring stop, the lower valve (2-parts), and two slightly different diameter metal washers used for gaskets.
3) Inspect the pump and determine if the piston is stuck. My inspected showed that the pump piston was stuck in the up position.
4) *** Important *** before removing the piston from the pump body look at the piston's top (through the valve body side). There is a slot on top of the piston. You need to where this slot is pointing so that it you can correctly re-assembly the piston back into the pump.
Note: There are two ways to put the piston back into the cylinder during reassembly. One is right the other is not.
5) Remove the pump from the cylinder: Put the pump in a vise with the valve assembly side up. I softly tap out the piston using a long flat tip punch. The piston, the piston's return spring and its retainer will drop out from the bottom.
6) Clean out the residual film from the piston and cylinder walls. (I used carburetor cleaning because I had it on hand. The tech manual suggested using dry cleaning solution)
Injector pump Reassembly:
1) Reassemble the piston into the cylinder making sure the piston is correctly orientated in the cylinder with top of the piston slot pointed in the right direction. Push the piston all the way up into the cylinder.
2) Flip the piston upside down so that you are looking at the cylinder’s bottom.
3) Using a slotted screwdriver, lightly tap it with a small hammer to mushroom (very slightly) the cylinder’s bottom wall edge. This will prevent the piston from dropping out for step 4 but permit the piston to ride up and down freely in the cylinder. Be careful. Only a very small indent is needed. The one I did was barely noticeable.
4) Install the piston's spring and retainer.
NOTE: this was not easy for me. I did it by putting the pump upside down in a vise, slipping the spring over cylinder, then installing the spring retainer. I used pliers to hold the retainer while pushing against the spring.
5) Install the value body assembly: Put the pump in a vise with the value body side up. First install the larger of the two washers, then the rest of components. These include the smaller washer, valve (2-parts), spring, and spring stop. Lastly install the valve body cap using an 18-mm socket.
Installing the pumps:
Note: The tech manual was very specific that the pumps are to be installed in a counter clockwise position. If it is not correctly install, then, the engine may not stop running.
1) With the pump in your hand, hold the bottom arm and rotate the pump’s valve body counter-clockwise.
2) Install each pump with its gasket set in the same place it was pulled out (“L” on the left side and “R” on the right). Be sure to place the injector pump's fuel line fitting to right of the hold down stud.
3) Install the hold down bracket on the stud and fighting the bolt.
4) Install the fuel line.
After I installed the pumps I tested it. It was successful in starting and in stopping.
