MA MEP-803A 10KW Slow Speed 1800RPM Military Diesel Generator, EMP Proof, Can Ship Nationwide $6700
Light in the Dark
6,053
MA
In Stock and can ship anywhere in the USA by tractor trailer. Will run on OTR diesel, off road diesel, home heating oil, and B20. If you have a home heating oil tank, you have fuel when the trucks stop running or fuel is not available! (9) 803A show, only 7 remain.
Slow speed 1800rpm design makes for significantly longer lifespans and reliability. The engine is a Lister-Petter LPW4 with an inline 4 design and cast iron block. Very rugged, very reliable. It only produces 70+ decibel at 20 feet... they are quiet runners! Only uses 1.1GPH @ 100% rated output.
All 10KW units (tan) have single digit hour meters! All gauges reading properly, and tested electronically for rated output. Additional photos available on specific machines by request. (1) MEP-802A 5-7KW unit available (camo). All machines are sold without batteries. Upgrades are added rodent mesh at ingress points, any necessary military wiring upgrades (quad fuse modification) as well as a power entry port... so you can run a battery tender when the machine is not being used.
Secure your home or business from whatever Nature can throw your way. Designed and tested against High Altitude EMPs before being fielded to our troops... this is the machine you want when it all goes sideways. Can ship to both residential and commercial addresses, as well as hold at terminal for you to pick up.
Any questions, please ask. Thank you
