cavalrymedic
- 0
- 0
- Florida
i acquired an mep803a in partial trade for a 37kw drash. it has 4k hours and runs like a top. BUT when i connected a load, air compressor, the compressor began to start, then immediately stopped and i do not test voltage at the convenience outlet, nor at the main output termimals. i have the gen on 1phase 120/240. the selectable rotary voltmeter only shows voltage between L1 and L3. it seems i may have popped a fuse or breaker that i do not know about. i checked the 7amp fuse and the bus fuse behind the operation panel. they are fine. the circuit breaker toggle switch on the operTion panel functions and the battle short switch is accounted for. what am missing?
