Hawaiian-Time
- 0
- 0
- Hawaii
Hi everyone.
I just got a MEP-803A everything looks to be all there and connected properly. Problem is it won't crank. I Have had a MEP-802A for some time now and know about the Kill switch, DC control power circuit breaker Button behind the Panel and the Fuse.
I did a little testing with the last of the Daylight I had left. Found that I have no power going to the Dead Crank Switch (in the Eng. Bay) or to the Control Panel for that mater. Then it got dark and here I am asking for HELP!. Usually I will figure it out all by my lonesome self but thought I would hit you folks up for a quick fix if anyone knows what might be causing this problem.
Yes the Batteries are fully charged and if I jump the Starter Solenoid the Eng. does turn over. This sounds like it's going to be an easy fix, I hope you guys can help. If not, It might be a sleepless night.
Thanks from Hawaii
Thanks from Hawaii
