baxter462
- 2
- 8
- Salt Lake City Utah
Hello,
Has anyone else had oil in their coolant, and coolant in their oil on an 805B generator. It is a JD 4045 engine. The coolant and oil both looked good a couple weeks ago when I last checked, but I ran it for a few hours this weekend and it shut down due to high coolant temp. The coolant was low, and had a lot of oil in it, and the oil had coolant in it. I didn't have a cooling system pressure test adapter that would work (I have since ordered one), but I figured the oil cooler was the most likely culprit since the fluid transfer went both ways, so I pulled the oil cooler and pressurized it with 80psi air while submerged in a bucket of water. I didn't see any evidence of leakage, so now I'm worried that something more serious is wrong. I may put it all back together with new gaskets for the oil cooler housing (which potentially could have been the entire problem) and do a little more testing once my pressure tester adapter arrives, but I'm wondering what other people have seen? It doesn't seem likely to me that a cylinder liner o ring is leaking, since oil is getting into the coolant also, and not just the other way around. I suppose it could be a leaking head gasket since there is a pressurized oil passage to the head, and it of course could be a cracked block or head, but I really hope not. Oh, and I did perform a "block test" to check for the presence of combustion gases in the cooling system, and it was negative.
Thanks
Thanks
