Thomas_G
- 7
- 8
- Houston, TX
I been restoring this unit and got it started. However I cannot get over 150 volts. I have a new controller card. The unit will also run then stop. Possible gov adjust needed?
Hi KurtIs the throttle linkage adjusted per the TM such that the gap between the magnet and the target is 5/16" at no load?
Can you measure the voltage at the lugs from L1 to Neutral and then from L2 to Neutral and let us know what you read?
