dependable
- 188
- 63
- Tisbury, Massachusetts
I had a couple on back order from Summit for a few weeks, and got a notice this week the order is canceled and refunded due mfg discontinued.
Both GAS and DIESEL are checked on the application chart for that pump. The application specialist I talked to on the phone gave me that one as one of the options to replace the E1074.Same pump is on Rock Auto for $27.79, but with that said... its called out for "large carbeurated Gas Engine" applications. I wonder if its diesel rated?
These appear to fit the bill, as stated above (trying to take the work out of it for those who read this later on). Please feel free to confirm these are what you bought Ray:If you are replacing the round E1074 with the adapter pipe you will need to buy two 1/4 NPT male x #4 JIC adapters , one 90 degree and one 45 degree. I get these from www.discounthydraulichose.com
I try to keep a couple pumps and a hand full of fittings on-hand incase a customer ever calls with a failed fuel pump, or one dies on a machine I'm working on.
If you want to install the G-17 strainer ( its not really a filter ) that is 1/8" NPT so you need to get the right adapters to install it in your desired location ( input to the pump )
Direct replacement for an 802a ?Look at what I stumbled upon this morning, for those that dont want to hobble together..
2910-01-470-7423 24V Diesel Generator Fuel Pump 88-22546 MEP-831A MEP-832A ⋆ DP Equipment LLC
24 Volt Diesel Generator Fuel Pump. 88-22546, E1074, 2910-01-470-7423. L4A1dpequip.net
Order is in. Thanks LITD.Look at what I stumbled upon this morning, for those that dont want to hobble together..
YupDirect replacement for an 802a ?
Just received my order for 2 fuel pumps. Glad to have them in the spares locker. Thanks again LITD.Look at what I stumbled upon this morning, for those that dont want to hobble together..
