OK, just throwing some thoughts out here...
Wondering if its possible that the new oil filter had some foreign debris in it that came out after initial start up after the oil change, or something entered system during oil change, and plugged an oil passage?
It doesn't take much to block an oil passage. I once was changing oil in a motorcycle and while drain plug, oil filter and fill port were open & exposed a June bug beetle managed to somehow crawl inside and I didn't know it and it later clogged a breather tube return passage that made an oily mess. Stuff happens!
I haven't tried this... but perhaps you could remove the oil filter and blow some compressed air (I would start with a lower psi setting ~30 psi) to see if you can establish any air flow though oil passages where the filter spins on? You could also take off the oil pressure switch and blow compressed air back through that port. I would also blow air backwards through oil cooler & its lines. Maybe take apart the oil breather assy and clean it while off and blow air through its passage. There might be other locations to access oil flow as well. If there is anything lodged in those oil passages it just might free the blockage long enough to allow it to run to confirm & then re-drain oil.
It just seems odd that this started after your new oil/filter change and right after oil change it ran for over an hour & suddenly quit, knowing now due to apparent loss of oil pressure.
Thank you for the tips. Do you know if there is anyplace where I could cause damage by doing compressed air
Problem solved!!!! I tried the compressed air and could not find any blockages. I was not looking forward to either doing the oil pump or the by-pass valve because of the major disassembly involved. I decided to flip a coin and the oil pump won. I removed the blower fan and took off the gear cover and a gear dropped on the ground. It was the drive gear for the oil pump. It had sheared off of its shaft. I unbolted the oil pump but the oil cup that extends down into the oil pan cannot fit through the oil pump opening. I think this is why they say you have to drop the oil pan. I fiddled with it a while and found I could unscrew the pipe between the oil cup and the pump and get the pump out. If anybody ever has to do this in the future, be careful when you unscrew the oil cup because if you drop it back into the oil pan, you are screwed. Might be able to fish it out with a magnet if you are lucky.
One other thing is that when you put the oil cup back on the new pump you must be extremely careful that you get it in the correct orientation. If it is not in the right position in the oil pan the crankshaft could possibly collide with it and the you have some big problems. (I haven't done this part yet).
Since I got the oil cup off I do not have drop the oil pan and the repair suddenly became pretty simple. I was not too concerned about debris from the failure in the oil pan since the gear that sheared off is totally outside of the oil pan and external to the pump. Just to be sure I took a magnetic parts pickup wand and fished around all over the inside of the oil pan through the oil pump mounting hole. There was nothing on the magnet!
Don't know why the gear sheared off. There was some minor damage to one tooth on the pump gear. Looks like it could have happened during the process of it shearing off. No damage to the inside workings of the pump itself (I took it apart).
Found a pump for $99 but 10 to 15 days shipping. I need the generator ASAP. The next best was $299. Should be here Wed, Thu, or Fri. I will let you all know when I got it installed and running!
If anyone wants photos, I can supply them.
Thanks to everybody for all the help!!!!!
One more thing. In my original post I mentioned the different sized gaskets in the parts manual. Those gaskets are internal to the pump and don't have anything to do with mounting it. The mount is inside the gear cover so they did not need or use any gaskets. So the only time you would need to be concerned with those gaskets is if you wanted to rebuild the pump. I guess Guyfang already pointed this out.
