Ray70
- 5,562
- 113
- West greenwich/RI
Yes they definitely are Priceless!
I purchased a 003A parts motor last year ( I wanted the IP out of it ) and the failure point was smashed up gears, with the crank gear being split open at one of the threaded puller holes.
The timing cover was also cracked as a result of the exploding gears.
I'm going to see if I still have the cover around here somewhere and see if the roll pin is intact or not.
Unfortunately the IP plunger was slightly rust pitted at the end, rendering it useless.
I think a little water / moisture had gotten into the IP through the disconnected line fittings and pitted the plunger.
