Ray70
- 5,615
- 113
- West greenwich/RI
You absolutely could. Just pull your 12V off 1 battery instead of 2. In fact you could most likely utilize the current glow plug solenoid and simply run a new feed to it that draws 12V from 1 battery instead of drawing 24V from the terminal strip as it currently does. That would also keep the original functionality of the glow plugs at start main switch.I know this is an old post. but............ I was wondering that since most are using two 12 v batteries, could you convert the plugs to 12v, run a circuit (12v) to the plugs, add a switch and heat em up from that switch. Thoughts................?????
I would have to consult the wiring diagram to confirm, but I think that would work just fine.
