The old switch is a Sunchro-Start model Go-3Ma Part # SA-1644 and I think it is nsn 5930010219378
The NSN 5930-01-021-9378 is listed in the TM-9-6115-465-24P, as a speed switch for the MEP-114A, (a 400 hertz, Precise Power Gen set) and so it can NOT be used on a MEP-005A.
and I believe TM 5-6115-458-34 and TM-07536A-35, DoD drawing # 70-4058. I also found on the trouble shooting schematic on the generator... Speed Switch- S9-1 Start disconnect and field flash, S9-2 Governor On Off, S9-3 Overspeed.
TM-5-6115-548-34. What has this manual to do with a MEP-005A?
Yes, the S9-1 is to disconnect the starter when the speed switch senses that the engine speed is high enough, and flashes the fields at the same time. On the MEP-005A, the S9-2 contacts are not used, as it is a utility gen set, not a precise gen set. S9-3 is to shut down the gen set when it over speeds.
On the new switch it is a REM PRODUCTS, SWITCH OVERSPEED nsn 5930-01-246-9266 P/N (80063) 70-1105-24. And then on another tag it says ELEMENT 1 Transfer 300 rpm P/N (80063), ELEMENT 2 Transfer 600 rpm 70-1105-24, ELEMENT 3 TRANSFER 1225 rpm LATCH
The NSN 5930-01-246-9266 is the proper NSN to fit the MEP-005A. The part number 70-1105-24 is not listed in the parts manual. Are the NSN and the part number both listed on the switch?
The only NSN that is interchangeable with 5930-01-246-9266 I know of, is NSN: 5930-01-023-4343
I would give my left nut to have a copy of FEDLOG. You need to get the right books, for the right gen set. Also important is UOC. That is Useable On Code. Whenever a part has a UOC list next to it in a parts manual, bells and lights should go off in your head. That means some parts will NOT fit every type of equipment listed in the parts manual. When you look at the cover of a TM, it lists all models covered in the manual. When you look up parts, look at the number of models, then turn to the Section 1, Introduction of the parts manual. Toward the end of the section, the UOC will be explained, and the proper code is listed next to the proper model and NSN from that model. That code will be listed next to the repair part you need. A good example is the MEP-005A. In the parts manual, are three different models listed. In the parts listing/table of contents, are two different listings for speed switches. One mechanical, one electric. Look at the first speed switch, and it shows TWO different NSN's. AND, a UOC listed next to both parts. Look at the next speed switch in the parts manual, and you will find ANOTHER TWO different NSN's listed. UOC listed next to them. That's 4 different NSN's, for one part. The UOC tells you what model the switches fit.
If the new switch is marked with 5930-01-246-9266, it is indeed the right switch. Do you know its good? Just because it looks new and shiny is not a sure sign its good. I have more times then I can count, ordered a part, unwrapped it, installed it and it was bad.
The top switch in your picture is a mechanical switch, the bottom one an electronic switch. The part number 70 1105-24 is not listed in the TM, for the MEP-005A. Like I said, my kingdom for a FEDLOG. FEDLOG lists any and all interchangeable parts. Will the seller of the part vouch for its serviceability?
